AMR Monster Coil?
AMR Monster Coil?
Saw this on Ebay, just wondering if anybody has any input on this coil.
http://cgi.ebay.com/ebaymotors/AMR-MONS ... ccessories
- Griffbones
the `monster` coil has more wire wound around it inside than a standard coil, this would produce a stronger spark which in turn should burn the fuel better & improve throttle response & starting, it would also maintain a good strong spark throughout the whole rpm range, i ran a similar upgrade on my 1000cc road bike which worked very well.
i thought about this upgrade for my kdx...recon with a irridium plug installed the combustion would be cleaned up ( for a 2 stroke) by improveing the way the fuel is burnt throughout the rev range making the throttle response better. i look forward to hearing your reply if you decide to purchase the monster coil.
- Griffbones
True. A stronger coil is sometimes necessary when increasing your compression ratio but otherwise is not needed.
- fuzzy
Replacing my source coil with one from Ricky Stator made a huge difference on my bike, but my OEM source coil was reading low on resistance....
My bike starts 1st kick every time, now, and has a killer top end.
(My OEM coil read ~175 ohms, the RS coil reads ~385)
2004 Dual Sported KDX200
1999 Ninja 250 (Daughter's)
