my friend has a 2008 kx250f and his clutch is having issues. when you put the bike in gear with the clutch pulled in, it will lerch forward and die. I have adjusted both clutch adjustments with no results. You can get it going by reving it high and poping the clutch, it will shift gears fine but when you pull in the clutch it wont stop. What could be causing this.
Thanks,
John
clutch issue
