Ever have trouble...
Mr. Wibbens
Post by Mr. Wibbens »
...getting the right side clutch/crank case cover to seal ??
Gasket looked ok
I torqued everything down and poured the oil in and the **** poured all over the floor
Took it all apart and repeated the above 3 more times :prayer: :prayer:
Same outcome :?
Maybe I need to drink some beer and then start over
Mr. Wibbens
Drank a few beers and the gasket appeared to be shot so I scraped it :partyman:
May try "The Right Stuff" tomorrow
BobbyZ
Post by BobbyZ »
Mr. Wibbens wrote:Drank a few beers and the gasket appeared to be shot so I scraped it :partyman:
More beer is usually the best solution :partyman:
dfeckel
Post by dfeckel »
I had a lot of trouble getting my clutch engine cover to seat fully the last time I had it apart. It turns out that I can't remember what it was hanging up on. let me go make some pancakes and I'll let my brain think on it a while. This has been a public service announcement from dfeckel.
David Eckel
dfeckel
Post by dfeckel »
Now I remember. It was the shifter shaft/mechanism. It looked as if the shaft was fully inserted and the mechanism all in the right spot, but it was not. It was just high enough to keep the clutch cover from seating fully. You might want to check the shift shaft and related mechanism.
David Eckel
Mr. Wibbens
hmmmm, could be I just replaced the shifter shaft :wink:
Mr. Wibbens
dfeckel wrote:Now I remember. It was the shifter shaft/mechanism. It looked as if the shaft was fully inserted and the mechanism all in the right spot, but it was not. It was just high enough to keep the clutch cover from seating fully. You might want to check the shift shaft and related mechanism.
'member what you did to get it all the way?
Mr. Wibbens
Some moran had a washer/guide in backasswards :wink:
WRONG WAY
And the RIGHT WAY
Pretty sure I did the same thing a 2 years ago and forgot all about it
Mr. Wibbens
Wow can't believe how much easier it is to find neutral with the motor running now that the lever is mounted so much more solid to the sift shaft
fuzzy
Post by fuzzy »
LOL OOPS. Good find.
LOL.
Dude, I did that exact same thing with a kx100 after we'd split the cases to replace a few transmission gears just a few weeks ago. Funny! I bet our clutch cover woulda leaked too. When we tightend the cover down and tried to shift, the shifter didn't move free. It was very stiff, and would stay wherever you put it. I jus happened to want to test it after everything was stitched up. We were gonna pull the motor back out and re-split, but I tried it again after he loosened the clutch cover and it would shfit just fine. Investigation behind the clutch cover turned up the flipped washer. We were havin beers also. Maybe beers and buildin motors really don't mix??
Mr. Wibbens
frankenschwinn
Post by frankenschwinn »
>|QBB<[/url]
Mr. Wibbens wrote:Image
You can buff that out.
