Page 1 of 2
I cant get my shock out!
Posted: 07:25 pm Jan 08 2011
by Fatherof2
I got it un-bolted with no problems, but I cant seem to remove it from the frame. Am I supposed to remove the air box? I am using Cyclepedia, and they make no mention of pulling the airbox. If I pull back on the top of the shock real hard, I just clear the mounting bracket that the top of the shock bolts to. Then the shock is so wedged in that I cant move it. Any words of wisdom? Figured I would take a break and ask the experts. Hope this makes sense.
Thanks very much for any advice,
David
Posted: 07:30 pm Jan 08 2011
by Indawoods
It comes out the right side between the frame where the nitrogen part is.
Posted: 09:20 am Jan 09 2011
by Fatherof2
Inda, that is exactly what Cyclepedia says. However, it just is not coming out. I think I am going to have to pull the airbox. Does anybody else have to do that to get the shock out?
Posted: 09:23 am Jan 09 2011
by Indawoods
Hmmm.... I never had any problem with it...
Posted: 09:35 am Jan 09 2011
by gregp
Sometimes you have to move the swingarm up, or down quite a bit to give you room to move the lower end of the shock around in the frame.
Posted: 11:55 am Jan 09 2011
by Fatherof2
I am frustrated! I have the the nuts and bolts that secure the tie rods to the rocker arms totally removed. I am flexing the swingarm up and down. I just cant weasel the shock out. I had to take a break due to frustration! Do I need to rotate the spring around as I try to gain every mm of space needed to pull the shock? Is this normally quick and simple with nobody every having any difficulty with this job?
I need help.
Thanks,
D.
Posted: 01:02 pm Jan 09 2011
by OLHILLBILLY
I had to take the airbox off of my H model to get it out. Manual says to remove: side covers, seat, rear frame pipe, rear fender, & air cleaner housing. I found that to be a pretty accurate description of how it had to be done. Older models may be different though.
Posted: 03:37 pm Jan 09 2011
by Mr. Wibbens
I bet the airbox could use a good cleaning anyway
Quitcher whining and take it off
Posted: 03:47 pm Jan 09 2011
by Fatherof2
I feel better knowing its not just me. Sure would have saved a LOT of aggravtion if Cyclepedia had said that. I think I can get it out if I take off the expansion chamber.
Turns out that the aribox does not need a cleaning. The bike only has 16 miles on it! What are the odds!
Thanks for the input.
Posted: 03:49 pm Jan 09 2011
by cornishwrecker220
would the removal of the lower link help...the shock should just drop out the bottom?
Posted: 04:39 pm Jan 09 2011
by Mr. Wibbens
Could always take the swingarm off
I bet ya there aint much grease on those bearings, even with just 16 miles on it
Posted: 07:42 pm Jan 09 2011
by gregp
I am pretty certain that the pipe has to come off anyway...
Posted: 07:55 pm Jan 09 2011
by OLHILLBILLY
gregp wrote:I am pretty certain that the pipe has to come off anyway...
Nope, pipe can stay on.
Posted: 02:48 pm Jan 10 2011
by gregp
Ok. I haven't taken my shock out yet, but I did on my old '96, and that was quite a while ago. So, is there a step by step for this operation?
1) remove seat and right side panel
2) remove rear dog bone bolt and swing dog bones downwards
3) remove upper and lower shock bolts
4) ????
5) ????
I have a new shock coming, and after I rebuild it and re-valve it, I will need to get it in there....
Posted: 03:12 pm Jan 10 2011
by Slick_Nick
In the time it's taken you to post all of this, you could have taken out and reinstalled the airbox about 13 times...
Posted: 03:35 pm Jan 10 2011
by Mr. Wibbens
as much as I hate to admit, I agree with slick
Posted: 03:51 pm Jan 10 2011
by Varmint
Posted: 03:55 pm Jan 10 2011
by Indawoods
I am not convinced.
Posted: 04:23 pm Jan 10 2011
by KarlP
4) ????
5) ????
1) EDIT- remove seat and LEFT side panel
4) Remove left subframe support (The right one is welded, yeah?)
5) Remove airbox
6) remove shock
Posted: 04:40 pm Jan 10 2011
by gregp
Great! Thanks!
