Hey there!
Hey there!
Postby Sjaak » 03:25 am Oct 09 2018
I'm Sjaak, I'm from the Netherlands, and just joined this community.
I bought a 1991 KDX200 a few months back, and rebuilding it now from the ground up because a crank seal blew. I finished the engine (all gearbox bearings, seals, etc. replaced too) and picked up the frame from the coater, so I can actually start building the bike now.
I hope to have fixed the problem of the KIPS by making new collars on top of the valves that barely allow any play (see picture for old and new situation). I thought that the single valve on the right in the picture had too much play when the gap of the collar was facing away from the rod, causing it to chip off teeth from the valve when there was a bit of carbon buildup. What's your opinion on this? Might the valves get jammed when the engine gets hot because the aluminum expands? (Gonna test it first by leaving the valves open and the governor disconnected, and see if the valves still move smoothly after blasting the bike around for a while.)
I found out later, there are steel KIPS valves available, so I'll definitely buy those if this doesn't work.
Thank you for having me in this forum, and I hope we can help each other out! Drive safe! :wink:
Sjaak
Has thanked: 0 time
Been thanked: 0 time
Re: Hey there!
Postby Jason » 03:49 am Oct 09 2018
Welcome to kdxrider.net. :bravo:
The frame and engine look nice.
Thank you, Julien D for all your hard work!
PLEASE! Do not "dip" PWK Keihin carbs in Berryman's to clean them! It will damage the internal o-ring (jet block gasket).
Jason
Images: 12
Has thanked: 158 times
Been thanked: 358 times
Re: Hey there!
Postby Greenbandit200 » 06:37 am Oct 09 2018
Well you got the right idea of testing it by leaving them stationary while it's warming up. This is the first time I've ever seen custom made collars, though I don't think you will have any problems since the collars and engine should warm up equally at the same time. The only problem I could think of is, if they are too tight when the carbon does build, they have a chance of seizing?
Good luck.
Greenbandit200
Has thanked: 0 time
Been thanked: 2 times
Hey there!
Postby Molly's 70 » 01:17 pm Oct 09 2018
Looks damn good :grin:
Has thanked: 13 times
Been thanked: 11 times
Re: Hey there!
Postby Sjaak » 05:31 pm Oct 09 2018
Thanks for the warm welcome guys!
Greenbandit200 wrote:Well you got the right idea of testing it by leaving them stationary while it's warming up. This is the first time I've ever seen custom made collars, though I don't think you will have any problems since the collars and engine should warm up equally at the same time. The only problem I could think of is, if they are too tight when the carbon does build, they have a chance of seizing?
Good luck.
I don't think the carbon would be much of an issue, as the valves will keep moving when driving. Considering the governor is able to push hard enough to chip off teeth of the valves, I think it won't let carbon buildup happen. I plan on taking it apart and cleaning regularly too, as it'll always be a weak spot on the bike. Thanks for thinking with me, still something to keep in mind!
Sjaak
Has thanked: 0 time
Re: Hey there!
Postby Jason » 08:20 pm Oct 09 2018
Plenty of people have let them go way too long and cake up with carbon. If you keep an eye on it, they will last a while.
You won't find many reports of people buying the bike new, then maintaining it fairly often and they still chipped teeth. Most are from people who bought the bike fourth hand from two or three people who don't know what a power valve is, much less how to maintain it. KIPS was on KDX in fall of 1985, time for those people to step up. :lol:
Jason
Images: 12
Re: Hey there!
Postby bufftester » 10:51 pm Oct 09 2018
Welcome!
Images: 168
Has thanked: 3 times
Been thanked: 150 times
Re: Hey there!
Postby Sjaak » 02:59 am Oct 10 2018
Jason wrote:Plenty of people have let them go way too long and cake up with carbon. If you keep an eye on it, they will last a while.
Agreed, the previous owner of my bike didn't seem to have any technical knowledge whatsoever. I came across things that'd just have me shake my head while I looked at it. I have replaced one of the valves already because it chipped off teeth. I read the maintanance interval is 2k km? I barely even drove that and it was ruined again already. If this gets messed up again, I'm gonna go with the steel valves.
Another fun thing, I just happened to pick up another KDX by coincidence, a 1980 KDX175 for a price a couldn't just leave it for. It's missing all of the electrics: stator, flywheel, even the spark plug, lol.
Sjaak
Has thanked: 0 time
Re: Hey there!
Postby Jason » 06:33 am Oct 10 2018
Looks pretty darn nice! :bravo:
Jason
Images: 12
Return to Introductions
Who is online
Users browsing this forum: No registered users and 6 guests
