Hi everybody from Scotland
jstcraig
Country: Australia
Re: Hi everybody from Scotland
Post by jstcraig »
cornishwrecker220 wrote:Just a small note....
If I were you I'd place some clips on the oil feed pipe where it joins the brass knuckles ...this will ensure the oil pipe is a nice tight fit & won't allow any air in should the pipe harden over time .... The type of clips like the ones used on the carb overflow/breather pipe should be fine.
Yep that’s what has been previously used and will be on the replacement hose,thanks for the input [emoji1303][emoji1303][emoji1303]
jstcraig
Country: Australia
Post by jstcraig »
Bugger I replaced the old hose with some 2.5 OD fuel hose and the friggin old clips are to big [emoji849]
