New rider with a 2003 KDX220R
Posted: 06:37 am Sep 14 2017
by MarkW
Mark Westerfield from Connecticut.
Friend hooked me up on a great deal on a 2003 KDX220R, nice shape, a few nice upgrades. Been riding with a friend at the Thomaston Dam and having a great time. Throttle has begun to stick a little so I'm trying to figure that out.
Anybody else have this bike? Have tips?
Re: New rider with a 2003 KDX220R
Posted: 10:46 am Sep 14 2017
Welcome to the forums. There may be one or two around here with a similar KDX.
Have you taken apart the throttle assembly or taken the cable off and cleaned and lubed it? Have you checked the throttle slide in the carburetor?
Posted: 11:36 am Sep 14 2017
by Dekon
Welcome.
You might also want to check if the original piston is still in it. The 220's have a known issue with cracked piston skirts(OEM only). There are quite a few threads on here with people having that issue.
Posted: 12:34 pm Sep 14 2017
Especially since it is 15 years old.
Posted: 12:54 pm Sep 14 2017
by doakley
Forget about the sticking throttle. The first and most urgent thing you need to do is determine what piston is in it for sure. If it is an OEM piston, get it out now. Too many owners on this site have had very expensive problems by not doing so. You can deal with the throttle in the process.
Congrats on the bike, one of the best trail bikes ever made! You're going to love it (after you deal with the piston!).
Posted: 07:08 pm Sep 14 2017
by bufftester
Congrats, and welcome, and what all they said ^
Posted: 09:39 pm Sep 14 2017
by Burtono
Hey Mark, I ride Thompson dam as well on my 1997kdx 220. My throttle also is slow to return some times only if the bike is dirty. I'd guess some dirt get under the throttle tube. Try washing the bike and seeing if the snap comes back. If it doesn't you may need to lube cable or replace some parts.
Posted: 10:13 pm Sep 14 2017
by doctord23
Also check the routing of the throttle cable.
It should run away from the exhaust or the heat can cause sticking.
Posted: 06:45 pm Sep 16 2017
by tmmyghst
The grip can also rub on the rubber boot of the throttle if the front brake is over too far, hitting the rubber boot.
Posted: 09:41 am Sep 18 2017
by MarkW
Thanks for the suggestions guys. The sticking throttle was the brake lever adjustment screw binding on the throttle grip, and I cleaned up the tube, while I installed Bark Buster handguards. I'll try to look into checking out that piston ASAP, thanks for looking out!
Posted: 10:46 am Sep 18 2017
I am glad to hear you got it sorted out
