New Member
New Member
Hello everyone, Just bought a 2003 KDX 220 Love my 2 strokes! I'm looking at doing some green laning and enduros.
One question I have to begin with is I want to fit some lights. Any one know what colour the live/neg is?
It has a silver box which I believe is cdi? and another box with wires. Would this be for the lighting circuit?
Hopefully this all makes sense
Cheers Gaz
Cheers Gaz
- diymirage
Re: New Member
welcome aboard
your 220 should have come with lights, so chances are MOST of the wiring is still in there
I would check under the seat for the tail light wiring, and under the tank for the headlight
I don't remember the tail light wire off hand, but on the head light, yellow is the hot lead
New Member
Thanks for the reply bang on the money....a red wire and a yellow tucked under the tank. The rear looks like red and a yellow/black one. All I need to do now is fit a brake light switch....any ideas?
Cheers Gaz
Cheers Gaz
Re: New Member
You can use a pressure switch that replaces the banjo bolt or under the right cover should be a bracket for a machnical switch that you will need to connect to the peddle with a spring. Pressure switch it the way to go IMHO.
- diymirage
Re: New Member
I run two brake light switches on my KDX
one is the pressure switch mentioned about, that replaces the banjo bolt on the front brake lever
the other is a the mechanical switch, mounted to the position mentioned above, and activated by a spring attached to the rear brake pedal
New Member
Thanks again for everyone's help. Got to say I'm already impressed with this forum
Re: New Member
Nearly there...just to confirm
1 Yellow wire to light switch, then wire to headlight. Red wire straight to headlight.
2 Sice banjo bolt wire into rear light live and Earth the other wire from banjo bolt
Cheers Gaz
Cheers Gaz
- diymirage
Re: New Member
correct
but when you splice the live wire to the rear, one will still go to the "dim" side of the bulb
the other will run through a switch to the "bright" side of the bulb
did anyone mention you need to buy a new socket in order to run a dual filament bulb ?
I believe the number is 1157
I bought a socket for my KDX on ebay for less then a dollar
- Tyl3r
Re: New Member
I just wanted to say something about those banjo bolt switches...THEY ARE AWESOME! lol I've replaced malfunctioning factory manual brake like switches on my quad and quite a few of my buddy's quads with no issues. They work great.
Also, figured this wiring diagram may help, I used it trying to figure out some problems with my old 200:
(disclaimer: I cannot take credit for this, Bufftester made it, the photo came from his Photobucket)
Re: New Member
Cheers Fellas....I'll let you know how I get on
New Member
Lights all sorted, low beam, high beam and brake light. Thanks for all the help.
