New to me 1990 kdx 200
Postby straitnate14 » 10:58 am Aug 09 2015
Hi. I just picked up a 1990 kdx 200 for $500 yesterday. It's been sitting for a few years but it's complete and hasn't been butchered like so many bikes of it's age. I put gas in it and it fired right up but it's a little tame for my tastes so I ordered a pipe for it off ebay. What kinda of stuff should I be looking for? I found a few loose spokes on the rear wheel I ordered a new tire and a few spokes. I drained the coolant and changed the oil over to type F like I run in all my Suzuki's. Clutch feels great and it shifts good. I think I did okay for $500?
This is what I have ordered so far:
carbon reeds
fmf pipe and silencer
bought a few jets to start tuning with
no toil airfilter
new grips
and a new headlight bulb
https://www.flickr.com/photos/134611689 ... res/1zg53o
straitnate14
Has thanked: 0 time
Been thanked: 0 time
Postby Gotanubike » 11:33 am Aug 09 2015
Nice clean E2! If you say the bike is too tame, part of the reason might be that the powervalves are roasted(they are infamous for stripping off the gears). They are made of some low strength aluminum from the factory. Check the E series section in the board index for thread on steel valves available from a small company in the U.K
1990 KDX200
Bike Profile -> viewtopic.php?f=103&t=14561#p136315
Suspension Overhaul(Shock+89-92 conventional forks) -> viewtopic.php?f=115&t=15255
96'-98' RM125 Showa 49mm fork swap -> viewtopic.php?f=104&t=16994
Gotanubike
Images: 20
Has thanked: 14 times
Been thanked: 14 times
Re: New to me 1990 kdx 200
Postby Jason » 12:23 pm Aug 09 2015
Welcome to the forums. Congratulations on your KDX.
Check the power valve system and reeds to see if they are mechanically sound.
Thank you, Julien D for all your hard work!
PLEASE! Do not "dip" PWK Keihin carbs in Berryman's to clean them! It will damage the internal o-ring (jet block gasket).
Jason
Images: 12
Has thanked: 148 times
Been thanked: 347 times
Postby straitnate14 » 12:28 pm Aug 09 2015
Can I check the power valve without taking the head off? I already ordered boyesen carbon reeds for it. It runs really good It's just my last dirtbike was an 01 yz 250 and it was a bit more peppy than this so I figured I'd throw a pipe and reeds at it and see what I gain. I have an 86 lt250r that I have ported and piped and it rips pretty good I'd say the kdx is on par with the lt power wise. I really like the bike a lot I just want to make sure I get it right.
straitnate14
Has thanked: 0 time
Postby Gotanubike » 01:18 pm Aug 09 2015
Yea you can check the power valves by taking the pipe off and looking down the exhaust. There are 2 on either side and one in the middle. Use the lever on the rigth side to toggle open and closed. tip: If ever disassembling that lever, the nut holding the lever to the shaft is reverse thread
1990 KDX200
Gotanubike
Images: 20
Postby straitnate14 » 05:32 pm Aug 09 2015
Well the power valves are moving freely. It runs pretty dang good I guess I'm just used to a little more power. I can get the front end up through third and I weigh 175lbs. I can't wait to see what the fmf pipe and the carbon reeds do for it!
straitnate14
Has thanked: 0 time
Return to Introductions
Who is online
Users browsing this forum: No registered users and 1 guest
