New Member
New Member
Postby metalkfab » 09:34 pm Jun 06 2015
New to the Site.Just picked up a 2004 KDX200 in sweet like new condition.I'm vintage Penton rider,done a few ISDTRR's.Also have a 2003 RM125 for MX fix,(as a practice track professional).Ready to build a Great woods rider/harescrambler. Where do I start? Impressed with the advice I've already read up on. Thanks
metalkfab
Has thanked: 1 time
Been thanked: 0 time
Re: New Member
Postby bufftester » 04:24 pm Jun 08 2015
Suspension needs to be sorted first, stock bike is unbalanced front to rear (way too soft up front, and soft in the rear for most). Then jetting. Those two alone will keep you up with most any bike on the track.
2001 KX/KDX 220 Hybrid, 1999 KLX 300, 1995 RMX 250, 1992 GSX-R600, 1993 GSX-R750, 1994 GSX-R750, 1995 GSX-R750
Jetting Guide | Scheckaet's Newb Guide | Suspension Goodness
Images: 165
Has thanked: 3 times
Been thanked: 134 times
Re: New Member
Postby Julien D » 06:43 pm Jun 08 2015
Welcome to the forum! If you have a pristine 200, there's not too much you need to do to have a great woods bike. Suspension first, then move on to power mods. At the very least make sure you have it sprung for your weight. After that, exhaust, carb/head mods, and re-jet.
Images: 7
Has thanked: 47 times
Been thanked: 125 times
Re: New Member
Postby Jason » 02:33 am Jun 09 2015
Hello, and welcome to the forums.
Read up on the suspension first.
Thank you, Julien D for all your hard work!
PLEASE! Do not "dip" PWK Keihin carbs in Berryman's to clean them! It will damage the internal o-ring (jet block gasket).
Jason
Images: 13
Has thanked: 96 times
Been thanked: 320 times
Re: New Member
Postby Rippin_RobMX » 09:26 pm Jun 09 2015
Welcome man! The first thing I did to my 04 KDX 200 was upgrade is the exhaust. (I only weigh 170lbs so the suspension is fine for me) I put the FMF Gnarly Desert (Rev) pipe and Turbine Core 2 on it because I ride in open areas more often then through tight trails. Getting rid of the stock Pipe really woke my bike up. Can't say much about the silencer because I have heard that it doesn't have and benefits over the stock except that it looks better. So depending on What type of riding you do should determine What you do first. Hope I helped a little! Ive included a couple of pictures of my kdx before and after.
Before
After: Image
I also have protaper bars which I like alot better over the stock ones. A maier Rear fender and acerbis hand guards. Just ordered vforce 3 reeds and a k&n air filter so I will update this one I get the results.
Rippin_RobMX
Has thanked: 5 times
Been thanked: 2 times
New Member
Postby metalkfab » 09:49 pm Jun 23 2015
To all of you,Thanks for the responses.Much appreciated.
metalkfab
Has thanked: 1 time
Return to Introductions
Who is online
Users browsing this forum: Theducman and 4 guests
cron
