New to forum (UK)
Posted: 01:35 pm Jan 05 2015
by Dogeatgod
Hi All
Really good forum, lots of information.
I've just picked up an '89 for a bit of green laning fun - don't know much about anything really but will learn pretty quick.
Other than being under-powered (all standard bits), having a warped front disk, bent bars and a leaky tap, all is looking good - new bars, disc and pads ready to be stuck on this weekend.
I found a free to download service manual for '89-'94 - davesbikes.weebly.com/manuals.html and hope to increase power a little by tinkering before committing to changing exhaust, jets and reeds.
I'm sure I'll ask some pretty green questions but please bear with me.
Cheers
Rick
New to forum (UK)
Posted: 02:13 pm Jan 05 2015
by Gotanubike
'89-'94 will be the correct manual for your bike, tho it is normally frowned upon to link to a free manual download. Not really a problem, but you may just want to edit your post or a mod will probably take care of it for you :wink:
If your kdx is under powered it's likely due to a KIPS malfunction or worn piston/rings/plating or all of the above. E series (89-94) models are kind of notorious for cannibalizing their powervalves resulting in them either sticking open(low bottom end power) or stuck closed(low top end). Only way to find out with be to open it up and have a look!
Good luck and keep us informed on the build
New to forum (UK)
Posted: 02:27 pm Jan 05 2015
by GreatBritishRob
Where abouts in old Blighty matey? :)
Re: New to forum (UK)
Posted: 03:26 pm Jan 05 2015
by Dogeatgod
Thanks for reply - I'll take a look at the powervalve operation tomorrow, as can do this without opening her up, low end power is what's missing.
If it is stuck open is there potential to damage the thing by riding it a little before stripping down and putting right or is it just performance that suffers?
Rob - SouthWest - Devon/Somerset border near Wellington.
Cheers
Rick
New to forum (UK)
Posted: 04:30 pm Jan 05 2015
by cornishwrecker220
Hi rick welcome to the forum...
I'm from Penzance in Cornwall , just down & to the left a bit !! :grin:
New to forum (UK)
Posted: 05:20 pm Jan 05 2015
by Dogeatgod
Nice part of the world - I picked up the bike from Camborne
New to forum (UK)
Posted: 05:32 pm Jan 05 2015
by Gotanubike
You won't harm the engine with bad powervalves....what you will want to look for is gear teeth of the left and right side + idle gear. They are made of a soft alloy that have a tendency to wear down over time. The rod that controls these, as well as the center valve are made of steel.
New to forum (UK)
Posted: 05:50 pm Jan 05 2015
Dogeatgod wrote:Nice part of the world - I picked up the bike from Camborne
That's 15 miles from me....
Was the bike on Ebay ?.....think I may have spotted it....is it road legal ?
Posted: 06:13 pm Jan 05 2015
by Dogeatgod
Thanks gotanubike that's really helpful - I expect there will be a fair amount of wear and I'll have to replace quite a few bits but at least I can have a play on the tracks before dismantling.
Yes, it was on Ebay around October time, road registered with V5. It passed an MOT just needed a sticker over the 'Not' bit of 'Not for road use' on the silencer, a speedo that connected to nothing, a horn only of use when the engine is not running and a number plate - all sorted in Cornwall : )
Cheers
Rick
New to forum (UK)
Posted: 06:21 pm Jan 05 2015
Some mechanical parts are a little difficult to get over here in the UK, but most are available if you search hard enough....MD racing in YEOVIL stock UFO plastics for the kdx & also levers etc .
