Hi all! From a broken KDX owner
petbeemer
Post by petbeemer »
Hello everybody, in the quest to source parts for my SR I came across this forum so thought it may be a good place to ask questions
Ive bought a poorly KDX 250 SR with a broken inner clutch case which im finding impossible to find a new one
argclh6670
Re: Hi all! From a broken KDX owner
Post by argclh6670 »
There's a member on another forum that I believe has most parts from a US model. If its the same parts I don't mind putting you in touch. You may need to also join that forum for ease. If interested PM me.
petbeemer
Post by petbeemer »
Thanks for that, mines the Japanese model and upto now it seems to be different to all the rest! I would give it a try however, you never know??
argclh6670
post osme pics if possible of the cover, i'd like to compare to mine.
petbeemer
Post by petbeemer »
Im having the case repaired atm but I doubt it will be successful
dude541
Post by dude541 »
are you in the uk?
I am sure I have seen this bike for sale on gumtree?
the parts for these are like rocking horse ****! but I may have found what you need..............
http://www.ebay.co.uk/itm/KAWASAKI-KDX- ... 41722adfc7
ignore the year, they always get them wrong! but it looks like the SR cover.
best regards
john
petbeemer
Post by petbeemer »
dude541 wrote:are you in the uk?
best regards
john
John
Yes ive put it on gumtree myself as it's taking up time and space now, however I would still like to get it fixed. That case on ebay isn't the same as mine either, mine has a thermostat in the water pump housing and is a lot wider there, total pain to find!
petbeemer
Post by petbeemer »
Don't know if this shows it that well but....
dude541
Post by dude541 »
well spotted!
and yes I think you will find it nearly impossible to find one unfortunately.
how did your repair go on the old one? as your advert more or less states that it just needs bolting back together?
regards
john
petbeemer
Post by petbeemer »
dude541 wrote:well spotted!
regards
john
John
Well I have it here now, engineering firm that welded it went a little over the top! but if I can dremel the inside of the case out to fit the start gear it should go back on but I would prefer a new one really
Part number is 14032-1324 for the one im looking for, Kawasaki here and Japan don't have any! hens teeth springs to mind!
dude541
Post by dude541 »
they probably stopped making them years ago! as it is an old bike, hence why you cant find one.
I even put the part number into a site in sweeden that hold over 23.000 Kawasaki parts from late sixties to early nineties, but they don't have one!
see if you can get the original working.
best regards
john
petbeemer
Post by petbeemer »
Well it's either that or go down the KX250 engine swap route, im unsure if they are a direct swap though, one on ebay now with a KX motor fitted
