whats up guys, so I recently rescued a 1985 YZ 250 from the graveyard. The top end was rebuilt very recently, the piston top and skirts are shiny, cylinder walls immaculate, ports on the cylinder spotless, etc. I dont think its ever been ran yet. cranks 180 psi cold, strong blue spark, brand new reed petals that seal perfectly and new gaskets, cleaned and rebuilt carb with stock jets and settings (everything on the bike is stock), new air filter, fuel line tank and filters are clean and im running fresh fuel. this thing wont even fire once with starting fluid
I found the timing was pretty advanced so I put it back to middle setting, still no fire. not a budge. Im stumped, yamahas always give me problems
Re: YZ 250 doesnt wanna run!!!
Posted: 01:43 pm Aug 01 2017
by david
Did you try a new plug
Posted: 02:04 pm Aug 01 2017
by jjavaman
Does it have spark?
Posted: 02:25 pm Aug 01 2017
by canamfan
Sounds like you have spark,fuel,and air along with great compression. It should fire, even if the timing is off you otta get something. I'd go back to basics. Maybe switch the plug, just in case, is the plug wet from fuel, is the pilot jet and passageway in the carb clean. One time I went to a race with my Yamaha and it wouldn't start, wouldn't push start, I forgot and left a rag stuffed in the intake when I was cleaning the aircleaner. You might pull the plug and shut off the fuel, kick it over with throttle open to clear excess fuel in the crank case. It should start, just take your time and go over things one at a time.
Posted: 04:49 pm Aug 01 2017
Here's a video of a guy who had a similar problem:
[youtube][/youtube]
Posted: 09:31 pm Aug 01 2017
by KDXrider1989
canamfan wrote:Sounds like you have spark,fuel,and air along with great compression. It should fire, even if the timing is off you otta get something. I'd go back to basics. Maybe switch the plug, just in case, is the plug wet from fuel, is the pilot jet and passageway in the carb clean. One time I went to a race with my Yamaha and it wouldn't start, wouldn't push start, I forgot and left a rag stuffed in the intake when I was cleaning the aircleaner. You might pull the plug and shut off the fuel, kick it over with throttle open to clear excess fuel in the crank case. It should start, just take your time and go over things one at a time.
exactly what I'm thinking, theres no reason its not even firing. i did put a new plug in and tried again with no prevail. ill give everything a look over once again
Posted: 08:43 am Aug 02 2017
by Burtono
In your first post, you did not mention anything about the exhaust. Did you clean and repack that?
Posted: 04:26 pm Aug 02 2017
by KDXrider1989
Burtono wrote:In your first post, you did not mention anything about the exhaust. Did you clean and repack that?
yes i did, header pipe was also burned to rid of old carbon. that has nothing to do with it starting though
Posted: 09:50 pm Aug 02 2017
by KDXrider1989
piston is installed correctly, tried retarding timing and it didn't work, advanced it again and still didn't work. didn't fire on starting fluid nor a good squirt of premix. exhaust is not blocked nor the intake, still has strong compression and good spark
Im completely stumped..... stupid yamahahahahas
today I got my brother to help, he drove his truck while I held on and then dropped it into 2nd gear. did this multiple times and it actually fired a few times but never actually started and ran. the timing was all the way advanced while doing this, and it only fired with the throttle wide open
Posted: 12:16 pm Aug 03 2017
by Dekon
Have you put a new plug in it? Sometimes a plug will give a great spark test outside, but under compression it will not give a spark.
Posted: 01:39 pm Aug 03 2017
But the manual and check out the electronics on the 32 year old MX bike.
Posted: 09:01 pm Aug 03 2017
by canamfan
Something to think about is the possibility someone in the past has bored out the stock jets, or cleaned them with a welding tip cleaner, which could greatly enlarge them, causing the bike to be getting way to much fuel. I guess the flywheel is lined up correctly? (key sheared) Just keep looking you will find it.
Posted: 12:01 am Aug 04 2017
by KDXrider1989
is there any way of testing a CDI with a voltmeter? I'm sure the CDI is partially responsible for ignition timing, maybe that portion isn't working correctly. Ive heard of putting the CDI in the oven at a low temp to "heal" it, or hitting it with a heat gun to make it temporarily function. I might have to split it open and check the soldering points, I don't know what to look for as far as worn capacitors go
yes it has a brand new plug, I don't have the manual and can't find a free online one, ill worry about jetting once I get the damned thing to start up consistently
Posted: 10:09 am Aug 04 2017
by Dekon
I need to check, but I think I have a Clymer manual for this.
Posted: 11:39 pm Aug 04 2017
by KDXrider1989
This doesn't look normal, almost seems like a capacitor or something inside the box blew up and melted the epoxy some causing it to bubble, I'll tear into it tomorrow
Posted: 12:58 am Aug 05 2017
Have you ever opened a CDI before?
Posted: 10:42 am Aug 06 2017
by KDXrider1989
Jason wrote:Have you ever opened a CDI before?
I have on some street bikes, Ill just be looking for something not normal like a loose solder or something obviously burnt. it was easy on those because the circuit board literally slid out, on this ill have to be careful cutting the box open
Posted: 10:46 am Aug 06 2017
Well, good luck on it. Maybe it won't get so horrible that you have to actually spend money and buy a service manual off eBay for a low price. GASP!!
Posted: 09:09 pm Aug 06 2017
by james85kdx80
Just a suggestion to save your right leg. Recently brought a kdx 80 back from graveyard with similar problem. Had compression spark fuel just wouldn't start. Rolled down long steep hill 4-5 times with no prevail. Chucked 1/4 socket adapter on 1800 rpm air drill with socket that fit flywheel nut and spun 20-30sec with throttle open. Heard drill slightly change tone pulled it off still on throttle and it still sputtered before revving up. Flooded one once and did same thing with 18v cordless drill. Tried with impact gun once but hammer effect just broke nut loose.
Posted: 08:19 am Aug 10 2017
by Dekon
Sorry, I was away on vacation. I did find it. I tried to PM you, but it wouldn't let me.
Here are the values:
Pick Up Coil Resistance: (YZ250N white to white/green) 90-110 ohms
Source Coil Resistance: (YZ250N brown to red) 157.5-192.5 ohms
