1985 kdx 200 piston substitute
- Country: usa
Ok I hate this being my first post to ask but.
I read where some people either tried or may be using later model year pistons in the 84-85 models
Can someone please confirm that they have ran this combo
Thanks In Ad vance
Thanks In Ad vance
Did you see this ?
I haven't run this piston myself as my 200 is a 240.
http://www.kdxrider.net/forums/viewtopi ... 19&t=21662
Re: 1985 kdx 200 piston substitute
Search for a post from KDX Geoff on the Wossner piston
- Country: U.S
Geoff, the way I read that is pv piston will work on 83-85 jug without modification?KDX Geoff wrote:Did you see this ?
Sent from my SM-S906L using Tapatalk
- Country: usa
I went to the wossner site I'm in need of a .020 over what you should I get? I'm trying to convert but not good at this
Thanks for the info guys
- Country: usa
Has anyone had an issue with the wiseco piston Rings hanging on the ports? Because of the pin location?
Just asking
Just asking
Has your cylinder been sleeved??
- Country: usa
Yea it has been not sure who did the liner as I just bought the bike. I found a 66.5mm Thanks for the help
The Wossner pv piston has the bottom ring a bit higher on the piston than the Kawasaki pv piston and on the resleeved barrel l have, it stops above the port so there's no issue with the ring end entering the port.F.I.S.H-1 wrote:Geoff, the way I read that is pv piston will work on 83-85 jug without modification?KDX Geoff wrote:Did you see this ?
So yes, no need to modify anything but check first as you can't assume that your resleeved barrel is exactly the same as mine.
This is a Kawasaki pv piston in a non pv barrel at bdc.
This is the Wossner pv piston in the non pv barrel at bdc. The ring peg on the bottom is on the left (the Kawasaki ring peg is on the right on their piston) and the ring end is not exposed to the port.
This is the pv barrel and piston. Very different porting and there's no issue with the ring ends.
- Country: PUERTO RICO
1986 oem piston is very,very similar,i own a 1985 kdx 200 A3 and i just find the oem 85 and the oem 86 and are almos the same,in fact the only thing they change between this two years are the 86 has a power valve but is air cooled. it also uses the same piston rings.ninjafreek wrote:Ok I hate this being my first post to ask but.
Thanks In Ad vance
