Is the best the Magura Jack Hydraulic Clutch setup? With or without extending the clutch lever arm at the clutchs?
I bought a Easy Stunt Clutch Pull Cable Lever System on ebay. It heped some, I lubed the cable.
I could aditionaly buy a teflon clutch cable and extend the lever arm at clutches at the engine. And keep using the Easy Stunt Clutch Pull Cable Lever System.
Hoping for fairly easy clutch pull, what is the best set up? Also any particular clutch rebuild kit reguarded as best?
Thanks for any info
Dan
Best setup for easy clutch lever pull?? 1989 kdx 200
Re: Best setup for easy clutch lever pull?? 1989 kdx 200
Hi Dan,
I have a Magura hydraulic clutch on mine and I love it. It definitely has an easier pull than the stock cable, but the best part is that it's way easier to modulate the clutch consistently. It was a tough pill to swallow ($$$) but after riding my KTM 300 with a hydraulic clutch, the choice was easy.
Rich
Rich
Thanks, I wonder which hydraulic clutch to get, I understand magura has a couple options.
For 1989 kdx 200.
Dan
For 1989 kdx 200.
Dan
