Exhaust valve installation
So I took off my cylinder head, had it shipped off for replating, it will be back eventually and when it returns I will also have to install brand new steel valves. I was unable to figure out how to even get the valve system apart, I can't find many resources online that make sense to me. If anyone can give me some help here that would be wonderful.
Re: Exhaust valve installation
Have you tried Cyclepedia?
I’ve been hearing a lot about the actuator lever and the arm, and needing to support that when messing with the valves. However when I originally took the jug off to inspect the cylinder and piston I didn’t know anything about that. My jug has been off for a while and I’m not sure how to tell if I broke the pin off the arm that’s inside the clutch. Can anyone show me an image of what these are?
- Country: New Zealand
