250?
Posted: 02:43 am Jan 22 2007
by tha_reids
I've got RB'd carb envy.
I know its advertized as a 200/220 mod. Also know I've got a 38mm carb so boring would probably not be needed. I was thinking divider plate, needle, thumb AS, and have the pilot circuit re-worked as needed.
Anyone heard of RB working on 250's?
Bike is a 92 250
Posted: 02:48 am Jan 22 2007
by KDXer
I'm sure Ron does the mods to a variety of different carbs so you may well be in luck. I have heard he does KTM and Yamaha stuff, PWK and FCR so fingers crossed.
Rons website wrote:Most all throttle cable controlled slide valve carbs can be modified
Posted: 11:52 am Jan 22 2007
by m0rie
I'd be very interested to see what Ron's magic would do to your 38mm and 250 combo.
Posted: 01:38 pm Jan 22 2007
by canyncarvr
It probably would be bored anyway. The bore makes up for some (if not all +) of the displaced volume of the installed plate.
You need to be the 250 guinea!!!!
Get the rest of the 250'ers on board.
Let us know how you like it!!
Posted: 12:36 am Jan 23 2007
by tha_reids
What I need to do is make a educated decision and not one motivated by impulse and peer pressure.
I'm the type of person who gets extreme satisfaction performing my own mods. Of course, after studying the subject matter at hand as to not be ignorant.
Lately I've been reading about changing the port timing. I'd probably puss out and only remove casting flaws and perform some light smoothing while leaving the timing alone. Don't know exactly what this bike would benifit from. Well, other than the forks being 86'd!
I would also like to leave any carb work to the pros if I choose that route. I remember enlarging my main jet on my first dirt bike when I was only 9. I pulled out a drill bit and went to town. It actually didn't ruin my jet and the bike ran well. Luck.
Maybe we can talk radonc73 or rick into being the guinea('s).
I know there has to be some tricked out 250's some where.
Posted: 01:42 am Jan 23 2007
by tim
I think Ron said he has been under the weather just wait he will chime in with the info you need on the carb mod.
Posted: 01:59 am Jan 23 2007
by tha_reids
Hope so!
Posted: 07:31 am Jan 23 2007
by radonc73
Radonc 73 was wondering the same thing
I am not to that stage of upgrading yet. The carb not sticking is waiting for its second long test, the suspension is probably next. I hadn't even heard of the RB carb mod before this site, so it wasn't on the long term list like the suspension. I would be inerested to see what the mod does.
Posted: 12:09 pm Jan 23 2007
by canyncarvr
Re: '...waiting for its second long test...
Meaning, it's had one?
Re: 'I'd probably puss out and only remove casting flaws and perform some light smoothing while leaving the timing alone.'
Don't mess with the port edges of a plated cylinder....right? You DID say, '..while leaving the timing alone.' That would mean NOT messing with the edges...but, just in case some words don't mean some things.
Posted: 12:23 pm Jan 23 2007
by radonc73
Ya CC, I took it for about a 45 minute joyride in some fields with no problem but that is far from a long term test. No hills and very few places to get WOT. That is the real test. Until then it is just sitting, resting, and waiting to be unleashed onto the world.
Posted: 02:05 am Jan 25 2007
by tha_reids
Unleash yourself, radonc73!
canyncarvr,
No timing changes at all. No modifications where the port meets the cylinder. Ports would not be raised or lowered at all.
If I ever did try anything drastic, I would pick me up a donor cylinder for sure. Only if I'm willing to take the chance of turning it into an expensive decorative flower pot.
Ya know, if I wanted my KDX to run like KX, I would just buy one
I just want it to be efficient.
Does anyone know if there is any negative effects to smoothing the beveled edge where the ports meets the cylinder wall? Not the cylinder wall itself. Don't actually think there would be any positive effects either just curious. Trying to set boundaries for myself
Posted: 05:47 pm Jan 25 2007
by fuzzy
I've been wanting him to do a 36mm PWK for my 250 for quite a while. One of these days I'll quit spending money on kart racing, and get it done.
