Quick carb question
- KDXer
Quick carb question
Going campin in the morning and thought I'd try the DEK in my Airstriker. I'm running 152/40/CEK-3/A/S 1 turn out. Would I need to change jet set for this needle swap ?? General consensus is DEK on clip 4 is it not ?? I'll be trying to get the SSS sorted with the DEK to see how I like that. Cheers all...
- bradf
I have the exact set-up in my 220 but is is not an AS, it's a modded stock. I switch from CEK-4 to DEK-4 a lot dependin on where I'm riddin. The SSS remains virtually the same and if I do touch it, it is cuz of temp change only.
You're already gone? I don't know what 'morning' is and WHAT morning you be talkin' about.
Anyway..if your main is right with the CEK, it will be right with the DEK.
Changing between the two (DEK-CEK) is fun. It's been awhile since I ran the CEK..I should stick it in for awhile.
Re: 'The SSS remains virtually the same and if I do touch it, it is cuz of temp change only.'
Me, too.
KayD...I missed somewheres that you weren't running on the SSS. I'm surprised at that.
What's your excuse?
Never mind...I really don't want to hear it.
Do it. You will know when it's right. There is no about it..it will be plain as day when it's 'on'.
Me, too.
Crikey! How long have you had this carb? And you don't have that sorted out, yet?Jedi Master Yoda wrote:Do, or do not. There is no 'try'.
What's your excuse?
- bradf
I am quite sure any excuse would certainly include those... and NO excuse would include 'em too!!
Probably ANY day he gets up before breakfast fits that list.
AND any night he didn't go to bed at all (so he wouldn't have to get up to eat breakfast) would fit, too. He's been known to keep some pretty weird hours.
...it's the bein' upside down part....agin.
