proper set up for stock carb - '99 220R
Hi, I apologize if the info is already posted in the forum, but what is the right set up for a stock carb? I just bought a '99 220R with about 20 hrs on it. everything is stock, everything is mint. The only issue was a mouse nest in the airbox! I have pulled the carb and reed cage. Thoroughly cleaned everything (there were little bits of fuzz in reeds). It is running much better now, but likes choke. I am wondering if the stock setting have moved or been fiddled with after all these years. any input if much appreciated. I have never adjusted a carb before, so detail is appreciated (i know there is a black plastic screw and a brass one). Many thanks, L8L
Re: proper set up for stock carb - '99 220R
http://www.dirtrider.net/justkdx/carbtuning.html
this should tell you everything you need
perfect, thanks spl383
