Ratio's
Frosty
Ratio's
Post by Frosty »
What's the best all around ratio to run I have an 84 200 fresh top end and reeds was thinking front end would have pulled up harder any suggestions? Riding stock ratio at the moments
dsmitty
Re: Ratio's
Post by dsmitty »
My 88 had 13/47 stock Maybe (48). I put a 12 on the front and it helped a lot. It took away some top speed but made slower riding much more snappy and I could ride a gear higher. If you ride sustained speeds above 50 mph a lot, and you have a few mods then you wight be happier with stock. Front sprockets are only $10 (plus shipping) so get a 12 and try it. Keep the 13 (stock) for riding in more open conditions or for when you mod the bike to the point it can "pull" the higher gear at lower rpm and still get the higher top speed.
Ratio's
check jetting guide in my sig.
jjavaman
Ratio's
Post by jjavaman »
Gear ratio or oil/gas ratio?
