drz conventionals
kdxtreme
drz conventionals
Post by kdxtreme »
Any one try drz conventionals like off of a 400.
kdxtreme
Post by kdxtreme »
So nobody has upgraded to more adjustable conventionals?
Did I say riding?
To hard to pin down.... expensive too!
kdxtreme
Post by kdxtreme »
Really there seem to be a ton of them on ebay just looking at other options. Maybe i will be the guinea pig with these.
Did I say riding?
Someone has done it.... just don't remember who....
kdxtreme
Post by kdxtreme »
I'll search around then. By the way kdx's rock.
Did I say riding?
You are right... they are finally making it to eBay! I may look into them... I prefer conventionals but it was not feasable when I did mine.
Are those 49mm? :shock:
kdxtreme
Post by kdxtreme »
I did a little research looks like 96 to 99 rm 125s are 49mm tc conventionals.
Did I say riding?
I still think 46mm is about perfect for the KDX.
49mm on a pig of a bike like the DRZ proly works great.....
kdxtreme
Post by kdxtreme »
Do the 46s come on the older kx 500s
Did I say riding?
chopper
Post by chopper »
The 96-98 RM 125-250's used the 49mm coventionals, once revalved probably the best woods forks ever used on a japanese bike. I have a set mounted on a CRF250X that were revalved by Drew Smith (WER) and they have been worth all the hassles required to mount them. If you're looking to buy a set, try to find a set from a 98 as they had upgraded slider bushings. I am about to begin a KDX hybrid project and I intend to use a set of these forks on it. My hybrid project is how I happened to find this site and has been helpful thusfar!
kdxtreme
Post by kdxtreme »
Cool good to meet someone with some experience with these. :supz:
Did I say riding?
chopper
Post by chopper »
BTW, the DRZ and the 96-98 RM forks are only the same externally, internally the RM's are twin chamber, the DRZ's are not.
kdxtreme
Post by kdxtreme »
Thanks good to know for sure.
Did I say riding?
When it comes to woods suspension... all the tricky stuff can be forgot about. A primative system is all that is needed. In my experience anyway... all the trick stuff is just another thing to have to deal with.
kdxtreme
Post by kdxtreme »
I agree its like the ktm people perfer the open chamber forks to closed chamber ones for nasty root infested single track and closed for faster whooped out riding.
fuzzy
Post by fuzzy »
The cool thing about the newer forks, in theory, is that you can potentially get them nice and plush in the shorter stroke, and still be able to take a huge jump. The older KYB's work great though. The factory forks/shock on my WR were straight YZ. They rock for high-speed open stuff right out of the box, but will kill you in the woods. I scored a full set of pro-action valved forks/shock setup for woods (even my weight) on ebay for $150. They are nice and plush, but still take adjustments and hits well, but are SCARY above 30mph. Takes about 30mins top to switch the whole shebang out.
kdxtreme
Post by kdxtreme »
Ok so I found a set for cheap local so how do I get ahold of [foots] since he's the one that has done this conversion on this forum. I need to pick his brain.
johnyblaze
Post by johnyblaze »
Those DRZ forks can be setup anyway you like them.... woods to MX. And, they're simple. Hope you pull this off. It would be a great alternative to the KX forks.
1998 KDX220 with goodies
2002 KTM LC4E
2001 Suzuki Bandit 1200S
kdxtreme
Post by kdxtreme »
They weren't in very good shape too many miles on them.
Did I say riding?
