Question on fork specs
Question for the fork experts here: So when a set of forks are labeled as "46mm inverted telescopic fork", what does the 46mm refer to? Is this the diameter of the fork? circumference?
- Varmint
Diameter of the fork tubes..... (The lower tubes)
Ok. Thanks everyone. So how do I figure out what diameter the forks are at the mounting points in the triple clamps? Do I measure the diameter with a caliper? Basically, I am trying to figure out what size yzf forks I have (got them for a very good deal) and which triple clamps will work with them. I am hoping to find a kx clamp that has been used by other people for the fork swap.
- Colorado Mike
- Varmint
- Colorado Mike
- Colorado Mike
- Varmint
- Varmint
Some bike of the same make with say.... 46mm forks, should fit any year forks from the same make (or fork manufacturer (i.e kayaba) of the same size... i.e 46mm.
I guess if you have YZF forks you better use a YZF triple clamp. Otherwise you'll likely end up in trouble with wheel spacing.
If you use a YZF triple, you'll only have to deal with the steering stem.
Do you not know what bike the forks came off?
'08 KTM200xc
KX100 for the boy
KX100 for the boy
Re: 'The OP was asking about diameter or circumference...'
..but he did use the word 'radius':
Granted, there isn't much to it...but words DO mean things. At this point I have no idea what is understood and what isn't...or the why of either.Do I measure the radius with a caliper?
