STIFFER!!!!
- 2FAST
STIFFER!!!!
First off im ok with the ride of the stock forks but im a BIG BOI sooo I press it down pretty far just by sitting on it I weigh 280 and yea lol!! Is there any way I can make them a little stiffer? I never jump or nothing just climb hill's and ride trail's and If I was to adjust the crew on bottom of the forks would it help any? and which way would I go for my weight on the rebound? ANY HELP WOULD BE AWESOME THANK'S IN ADVANCE JEREMY...
2005 KDX 200
2005 Raptor 350
2007 Grizzly 400
2005 Bruin350
1995 Bayou 300
1995 Magnum 425
1986 XR 250
2005 Raptor 350
2007 Grizzly 400
2005 Bruin350
1995 Bayou 300
1995 Magnum 425
1986 XR 250
- MXOldtimer
You need springs frt & back, start here. http://frpoffroad.com/kdxposed/suspensionTips.aspx
Racetech says (for 280# on a KDX):
FRONT FORK SPRINGS
Recommended Fork Spring Rate: 0.508 kg/mm (use closest available)
Stock Fork Spring Rate: .350 kg/mm (stock)
Available FRSP 3647 Series Springs are:
REAR SHOCK SPRING
Recommended Rear Shock Spring Rate: 5.76 kg/mm (use closest available)
Stock Shock Spring Rate: 5.0 kg/mm (stock)
Available SRSP 6228 Series Springs are:
Check out their recs at racetech.com.
Historically, RaceTech's recs are on the high side.
From MX-Tech:
Stock Spring Rates:
Fork: 0.37kg/mm
Shock: 5.0kg/mm (I put this in)
Recommended Spring Rates:
Fork: 0.50 kg/mm
Shock: 5.8 kg/mm
..the same as RaceTech.
In any case, at 280#, you're WAY off the mark with the OEM setup.
Thanks in advance Jeremy? That's you...or you think Mr. Wilkey (Jeremy..MX-Tech founder/owner) hangs around these parts? Not much chance of the latter.....
FRONT FORK SPRINGS
REAR SHOCK SPRING
From MX-Tech:
Stock Spring Rates:
Fork: 0.37kg/mm
Fork: 0.50 kg/mm
Shock: 5.8 kg/mm
- 2FAST
