Fork Oil Level
N8Strine
Fork Oil Level
Post by N8Strine »
What is the fork oil level suppose to be set at for a 2004 kx 250?
Jeb
Post by Jeb »
A lower level seems to make for a little cushier ride in the woods . . . I think acceptable fork oil levels run from 90mm - 140mm, so at the lower range. Try 115-120mm for starters. Try your best to get the level in each tube the same.
Where are you at now?
CLICK FOR PICS!
