conversion questions
- kicknrocks
is there a difference between a kx250/125 shock?
Any idea what years shocks/trees are compatible?
Will a 125 tree fit a 250?
Given a choice, which shock would be preferable?
Anybody know anything about kayaba shocks?
Are a 125/250 wheel interchangeable?
Will I be better off to revalve a stock fork, or buy aftermarket?
I'm sure I'll be back with more. You guys are, like, geniuses and stuff.
'01 KDX 220
Frisbee air box
RB Designs Carb
FMF Gnarly Woods
Frisbee air box
RB Designs Carb
FMF Gnarly Woods
- 2001kdx
Re: conversion questions
kicknrocks wrote:is there a difference between a kx250/125 shock?
Yes.
125 will have a lighter spring and may be valved differently. Otherwise Identical on the Kawasaki 125/250.
Not really :(Are a 125/250 wheel interchangeable?
I believe so.
Do the conversion. There is a lot to gain by just simply running a set of KX forks after rebuilding them, and with a full woods revalve, you've got heaven.I'm sure I'll be back with more. You guys are, like, geniuses and stuff.
- kicknrocks
- kicknrocks
SWEET! Just snagged a pair of forks for 113 and triple tree for 62.51. Hope the Applied triple tree (oversized upper, OEM lower) wasn'a a waste of money.
So I need the wheel and axle, anything else on the bottom?
I understand that I need machine work, pressing and knurling. How do I find a machinist that understands this process?
With all the talk about shim stock/spacers/beer cans, which direction should i head? Can I use a beer bottle?
[/img]
[/img]
[/img]
[/img]
'01 KDX 220
Frisbee air box
RB Designs Carb
FMF Gnarly Woods
Frisbee air box
RB Designs Carb
FMF Gnarly Woods
- Rick
Cool! The kdx stem needs to be pressed out, through the bottom. Get it, clamp on the bottom, pushing the stem out, through the bottom.. The kdx stem will be loose in the new kx bottom clamp. Just find a local machine shop. Show them the parts, and tell them u want to knurll the stem, to be tight in the clamp. They well prolly press it in 4 u. Just remember, there is a cir-clip on the bottom of the steering stem.
1996 Suzuki DR 350 $Sold!
2004 DR 650se Road Warrior
2002 DL1000 V-STROM
2002 DL1000 V-STROM
- scheckaet
not all clamp needs knurling, mine didn't. i let my local shop do the swap, for like 25 bux.
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- scheckaet
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
- Rick
- kicknrocks
I like the dude who calls it "knurkling."
Everything on my conversion is '01, not that that helps nor harms my case.
so I want the stem to be slightly larger than the lower TT? what dimensional difference am I looking for, and what's the threshold for knurkling/not-knurkling?
Still looking for some info on that TT I bought (Applied), and what else will need swapped or be compatible on the front end. I assume the wheel and axle, but what about caliper and disc?
'01 KDX 220
Frisbee air box
RB Designs Carb
FMF Gnarly Woods
Frisbee air box
RB Designs Carb
FMF Gnarly Woods
- scheckaet
Sounds like you need to read the stickies
http://www.kdxrider.net/forums/viewtopic.php?t=512
http://www.kdxrider.net/forums/viewtopic.php?t=146
Here is my 01 conversion
http://www.kdxrider.net/forums/viewtopi ... highlight=
Sold ☹ DRZ 400 SM
Sold ☹ DRZ 400 SM
