Will 1994's work
WOLFYMAN
Will 1994's work
Post by WOLFYMAN »
Looking at a pair of 94 forks are they what I want for the conversion. Or should I look for a newer pair. They woulkd be going on an 04 200 thanks
WOLFY
Ondatrail
Post by Ondatrail »
Look for a newer pair :wink:
I am the Night Rider! I’m a fuel injected suicide machine! I am a rocker, I am a roller, I am the out-of-controller
WOLFYMAN
Post by WOLFYMAN »
Thats what I thought, bidding on some 98's. But theres a set of 94's for 80$ plus 25$ on E***
WOLFY
2001kdx
Post by 2001kdx »
94 KX forks would be a good size improvement, but a '96+ model would be much worth the money.
Lutz
Post by Lutz »
I have a set of 1994 KX 125 forks on my 1995 KDX - vast improvement over stock. But yes, the newer forks (96+) would probably provide better action.
Keep It Simple Stupid
WOLFYMAN
Post by WOLFYMAN »
What if i'm going to respring and valve the the 94's
WOLFY
tommorth
Post by tommorth »
am curious about this to have a 94 kdx with stock usd wondering is 93kx forks would be much improvment (might b a cheap kx125 with sick motor nearby)
beware the mighty kdx
grump99
Post by grump99 »
I used '96 forks on my kdx conversion ('04 kdx). They are worlds better than the stock forks. I believe '96 is the first year for the 46 mm fork tubes, so they would probably flex less than older forks.
I would try to find the best condition forks you can. Most older forks will probably need new seals and possibly bushings. Make sure you factor this into your cost equation.
Good luck!
