KX 500 fork conversion project bike finally gettin goin
- TopperHarley
This one was a drop in fit. 2000KX500forks in an 03KDX frame. Just had to modify the stops a bit. I have been thinking about and gathering parts for this bike for a year and a half. Finally getting her together.
some pics here http://kdxrider.net/forums/modules.php? ... _album.php
2005 KDX220 mine
2005 KDX220 mine
- TopperHarley
bearings and stem were same as KDX. No trip to the machine shop to get stem pressed out and into KDX lower. also, the forks are a bit shorter than KX125&250 forks. Therefore, you do not have to set them so high above the top clamp to get the bike to sit level.
2005 KDX220 mine
2005 KDX220 mine
- TopperHarley
inner tubes ar 46mm. yes, the have adjustable comp. rebound damping.
2005 KDX220 mine
2005 KDX220 mine
- TopperHarley
I may be wrong on the length now that I compare to my 03KX250 forks.bearings and stem were same as KDX. No trip to the machine shop to get stem pressed out and into KDX lower. also, the forks are a bit shorter than KX125&250 forks. Therefore, you do not have to set them so high above the top clamp to get the bike to sit level.
Someone else told me they were shorter. I took their word for it.
2005 KDX220 mine
2005 KDX220 mine
- TopperHarley
I did fins someone who had done a conversion using KX500 forks with a YZ triple. they ended up changing their tubes to YZ USD because the valve stacks were more versatile thank the KX500 were. I will be going gold on mine, when I can afford it.
2005 KDX220 mine
2005 KDX220 mine
- TopperHarley
im not sure if the 2000 and 1999 kx 500 forks are the same. dealer may be able to tell you for sure.
2005 KDX220 mine
2005 KDX220 mine
