Shim stack help
- krazyinski
hell I wish could send my suspenders off to MX-Tech and get them worked over, but my wife refuses to sell one of the kids.
- krazyinski
so are you afraid to share with every one else?
- bradf
Gimmie your e-mail addy. My valving is good for 99-02's that have mid-valves. If yours has a check plate (CV) then that is a difference that will have to made up by adjusting CV lift. Also mine had a bladder and I did a simple yet very affective mod to eliminate it and the restrictive barrier's function.
- krazyinski
mine are 98's do you have the set up for what was done to the showa? i have a 2001 showa I am going to use. email krazyinski@hotmail.com
Thanks Brad.
- krazyinski
Thanks Brad. your base valve shim stack is close to mine except I have only (3) 24's the rest I have yet to investigate. I did have (4) 24's but removed one trying to get a better ride out of the forks with the .43 springs. now with the .40 all is well.
- bradf
- krazyinski
I can feel the differance in the mid stroke the next seal change I will investigate the CV lift. after Xmas I can get the rear shock done.
- Colorado Mike
- bradf
CM, your CV is on the end of the rod. The midvalve circuit is located directly behind the piston or opposite side of the piston than where the nut is. The CV is like a digressive dampning device. Instead of controlling flow with shims it simply uses a spring behind a spacer/washer to open when enough pressure is present. It is an ON/OFF circuit. The higher the lift (amount of travel the spring allows washer to slide open to allow oil flow) the lower the HS dampning affect is. Your lift would normally be about 1.3 mm. I think that 03's had a 2 stage MV stack as well.
- 80elkster
Has anyone tried Brad's setup yet? I'm about to on my son's 99 KX250 forks, but what I need to know is do we need additional shims for the midvalve setup? I don't know what shims are present on the midvalve and if we need to add some. Brad please help me out here.
06 DR650 Farkled
91 WR250 2T
00 300EXC (Sold)
79 XS850 (Sold)
79 CR250 (Sold)
78 IT400 (Stolen)
75 G5 100 Kawi (Gave it away)
73 F7 175 Kawi (Sold)
70 175 Brigestone (Recycled)
05 KDX200(Son's)
93 KDX200
75 KT250 Trials
250 Quads
Just glad to be ridin!
91 WR250 2T
00 300EXC (Sold)
79 XS850 (Sold)
79 CR250 (Sold)
78 IT400 (Stolen)
05 KDX200(Son's)
93 KDX200
75 KT250 Trials
250 Quads
Shims ARE spendy. That's the main reason I haven't replaced all of mine..which happen to be 15s (.15mm/.006"). The 10s (.10mm/.004") seem to be the choice of most.
CM...I thought you commented on bradf's posted animation. You didn't see it?
There are a couple of things that are not right. Honestly, I did not study every word said...maybe I missed it.
Here goes a few:
Re: Can't see the stack.
Answer: In the picture, the silver line under the gold part.
Yes. Part of it. The compression stack (of the base valve, naturally). This can be single or double stacked. In your case it's a double stack because you have two 'cones', right?
Bradf said (paraphrase), The shim closest to the piston has to cover the holes.
CM said, 'Brad, the check valve washer I have completely covers the holes in the GV'
You guys are talking about two different things, there. Brad the 'closest SHIM'..and I believe he's referring to the shim stack...I mean, he SAID shim.. CM..you are talking about the check valve which in your configuration is on the rebound side of the piston.
DO your 21s cover the holes on the piston?
Check this:
Notice the brass-colored spring loaded thing sitting on top of my piston? Same sort of deal.
Bradf's is the same way. I''m saying, he doesn't have a stack of shims on the top side of the piston, either. He has a spring/washer/sleeve for his checkvalve portion.
OK...so that's all good, right?
Your low speed setup is odd, because there is no taper to it at all. Simply a stack of 5x21s and then the 12 which is a transition shim, separating the two stacks.
Where you will find the rebound stack (if it's there) is on top of the midvalve piston. Obviously, the rebound stack is upside down from the compression stack...in each case the widest starting shim is against the piston, in each case that shim has to cover the piston ports to be doing anything.
CM: If you end up ordering a pile of shims (and they are going to be .10mm), please keep me in mind. I will split the cost of the mess with you if that works to your advantage. You can see my stack in my bike profile..basically I would want to start at least with .10s to replace my .15s.
Any of this make any more sense than you had before? Less?
Here goes a few:
Check this:
Whether you need more shims or not of course depends on what you have.
Bradfs setup is something like 36 shims per leg. There is re/comp and LSC/HSC for both on the midvalve.
