Triple clamp spacer, top or bottom of upper triple?
strider80
Post by strider80 »
Does it matter if the spacer (most people use the KX stem nut) goes on the top or bottom of the upper triple clamp? I am going to machine a one piece sleeve/spacer to deal with the up and down slop as well as the slop on the shaft and I can't decide if it matters which way the up and down spacer goes.
As of now I am going to put the spacer underneath between top triple and stem nut so that on top it only has the stock washer and triple nut.
This is on a 2000 KDX 200 with 2001 KX125 forks.
2005 KTM 250EXC
2000 KDX200 (gone)
Most put it on the bottom for clearance issues for the bars and to raise the top triple so that you have more adjustablity in the forks as most are longer than the KDX forks.
Just put it under the TT's! :wink:
strider80
Post by strider80 »
Thanks, just needed a little reassurance! I will post the dimensions with of my final spacer when I machine it and fit it up.
2005 KTM 250EXC
2000 KDX200 (gone)
IdahoCharley
Post by IdahoCharley »
FWIW - My stem bushing thickness was 1.0 mm or ~.040 inchs thick to take out the stem slop. Perfect fit IMO.
It looks like your is going to be closer to 1.5mm or .060 inches. Strange!!
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
strider80
Post by strider80 »
I am going to machine this tonight and see how it fits. The wall is 1.49mm (.059"). This should give me about what the factory KDX and KX slop is between the stem and triple.
2005 KTM 250EXC
2000 KDX200 (gone)
grump99
Post by grump99 »
:supz:
IdahoCharley
It looks like you are on track for a sweet set-up.
KTM 380EXC Mine
KDX 200 Mark's
TTR 125 L Wife's
KDX 200 Austin's
EC 300 Tyson's
WR430 Husky - mine
strider80
Post by strider80 »
I got it half machined after work today, should be good to go tomorrow. I should be swapping the steering stem tomorrow. I blatently copied kev200's steering stop. Otherwise I am good to go!
2005 KTM 250EXC
2000 KDX200 (gone)
m0rie
Post by m0rie »
Good deal. The steering stems should press out pretty easily...12 tons of pressure and some heat if it not coming right out.
strider80
Post by strider80 »
10 tons to press it out, 1 to 2 to press it back into the KX triple. Hopefully it will all go together this weekend!
2005 KTM 250EXC
2000 KDX200 (gone)
