Spring survey...
- Colorado Mike
Spring survey...
I'm just wondering what you guys are coming up with for spring choices. I find the recommended spring rates on the Racetech site to be pretty worthless for woods riding, so how about you folks that have done the conversion list your riding weight, spring rate, and what you think of where you're at?
Mike
'04 KDX220
'04 KDX220
- bradf
.42's with stock 5.0 rear spring. 200# strictly woods baby!
.43 w/5.0 rear
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
2005 KLX 125L (SONS)
2003 KTM 50SX Pro Jr
B Senior # 254/0092
Thanks to my 2008 Sponsers:
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
Ride weight 192#
.38 RaceTech springs off ebay ($41)
I tried .40s and .42s on my OEM forks, didn't like either one of 'em.
My forks came with springs that I measured to be .40/.42. Offed them before I even rode with 'em due to my previous experience with that rate.
I stick to the woods.
Well...going to Ski's this weekend to ride some well maintained freeways (Ooohhh...he's gonna make me pay for that! )..but it's woods in this neck-of-the-woods.
- m0rie
I'm starting with the stock .38's in my KX forks and will work up from there. Still using the stock 4.6 shock spring but need to get my shock rebuilt before I can determine if everything will be balanced. 170lbs nekkid.
Woods riding with a dash of faster pace desert riding thrown in once or twice a year.
***edit***
After tearing down the forks to service them i'm not sure if the stock .38's are in the forks or not. It looks like somebody has been into the shim stack judging from the stakes on the retainer nuts being filed off. Possible that the springs could have been changed at the same time. When I pull the forks apart again for the next service i'll measure the weight of the springs. They feel pretty good though.
***edit***
1989 KDX 200
2007 TTR-50E
2007 TTR-50E
.42 front Mobil 1 ATF @ 110mm
5.0 rear Mobil 1 ATF
168lbs nekkid
That is the setup that worked best on my 89 KDX with 41mm 90 KX250 forks. I started with .38/4.6 combo and liked the stiffer spring setup better (maybe because of the Mobil 1 ???) Everyone that rides this bike is amazed at how well it handles for it's age.
YMMV
168lbs nekkid
YMMV
- KDXer
.38's in my KX forks with gold valves. Stock 5.0 shock spring but need to get my shock rebuilt also before I can determine if everything will be balanced. 170lbs nekkid also.
Mainly single track with some 3rd-4th gear stuff and occasional MX track.
I weigh about 185lbs, and the .43 springs work great with the rear shock which was re-valved. The bike is VERY BALANCED and handles AWESOME and DOES NOT RATTLE YOUR TEETH OUT.Green Hornet wrote:.43 w/5.0 rear
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
2008 KLX450R
2008 DRZ400SM
2005 KDX 220R
1985 KDX 200A3
B Senior # 254/0092
John W Read Jr
