debating on KX front end swap
I have read a LOT about the KX front end swaps and am thinking of doing it to my 2000 KDX220R.
From what I have gathered a 1996-2004 KX500 is a bolt on front end so I would prefer to do that. I also see RB shows a service for the KX swap... I assume that's for the 125 and 250? Not sure what years.
The hard part seems to be finding an entire front end with the wheel and everything. I am also very hesitant with my limited knowledge.
I found a KX500 front end that says its a 96-04 for $350 but doesn't come with the front wheel or anything. Would I just need to buy a KX500 wheel? Will the KDX220 brakes work or would I also need the KX500 brake caliper and rotor? Here is a link... http://www.ebay.com/itm/96-04-KAWASAKI- ... 3641.l6368
2000 Kawasaki KDX220R
1996 Kawasaki KDX200
Re: debating on KX front end swap
From a quick search it looks like I can buy a front wheel with rotor in the ballpark of $60 or so. Brake calipers look to go for $30 ballpark. Should I buy this KX500 front end?
- KDXohio
Where are you located I have a 90 kx125 roller that Ive been saving in case I aquire another kdx but would be willing to part with it for the sake of getting more garage space. Front end is a direct swap would need to service the forks before installing as I don't know if they leak or not. Also I believe its missing the caliper but I think the 220 caliper will work? Someone else will have to chime in on that one.
- KDXohio
Here is the thread from way back when we I did my swap it may be able to help out some
http://www.kdxrider.net/forums/viewtopi ... 04&t=14226
I am located in Missouri. I'm not sure if I would want to go through a frame swap like that, the front end swap sounds like a lot easier of a project.
- KDXohio
The 90 kx125 front end is a direct swap like the kx500 I just meant you have to take the whole thing so its out of my garage!javjacob wrote:I am located in Missouri. I'm not sure if I would want to go through a frame swap like that, the front end swap sounds like a lot easier of a project.
I thought the 89-94 KDX was completely different from the 95-06 KDX? Mine is a 2000 model. I'm not sure how I would be able to get it anyway since it would be hard and expensive to ship an entire bike.KDXohio wrote:The 90 kx125 front end is a direct swap like the kx500 I just meant you have to take the whole thing so its out of my garage!javjacob wrote:I am located in Missouri. I'm not sure if I would want to go through a frame swap like that, the front end swap sounds like a lot easier of a project.
- KDXohio
They are very different but the steering stem is the same.
Bolt on complete front ends
kx500 USD front ends
90-91 kx125, 250
93-94 kdx200
Kdx250
The KLX front end I do not know the years that work here
Yea it wouldn't be worth it I was hoping you'd be closer by and we'd just meet up.
90-91 kx125, 250
93-94 kdx200
Kdx250
Yeah if we were closer that would be a good deal
- G22inSC
It's really not that big a deal. Pick your front end up with wheel and axle. Send both the KDX and KX stem/triple trees (along with a new bearing) to Ron black for his swap and bushing service. Bolt KX triple tree with KDX stem on your KDX frame then mount the KX forks, KX wheel and axle while probably being able to use your KDX brakes.
The hardest part is shopping for the best deal online, unless someone on here hooks you up.
'10 Honda Recon (wife's)
'08 Kaw KX65 (Sold)
'07 KTM 50SX Sr. (Sold)
'09 Yam PW50 (retired)
'97 Kaw KX250 (Sold)
Gallery
2005 KDX200 Bike Profile
'08 Kaw KX65 (Sold)
Gallery
I bought the 96-04 KX500 front end. I wont have to send it to RB and it comes with a set of fat bars. I just need to get a front wheel. Will only the 96-04 KX500 front wheels work?
I also bought a front wheel off a 96 KX250 which is the same as what the 500 used. Should have it all this week. I would like to have it revalved and whatever else it needs like lowering it to match the rear. Not sure of who is a good suspension shop yet though. I also bought a 1.125" kouba lowering link for the rear so I will need the front lowered more than what the forks will slide up in the triple clamps.
- Country: Usa
I am also considering fork conversion I have a 05' ' kdx 200 is this mod worth the effort ??
- KDXohio
Really depends on your riding but it's not much effort and typically not too much more expensive than rebuilding valving and springing you're stock Forks it also eliminates some overhangKdxgreg wrote:I am also considering fork conversion I have a 05' ' kdx 200 is this mod worth the effort ??
- G22inSC
Best mod I ever did was suspension and especially a Scott's steering damper. Makes a world of difference.
'08 Kaw KX65 (Sold)
Gallery
'08 Kaw KX65 (Sold)
Gallery
