Page 1 of 2
outer bearing races swap Hey great site New here
Posted: 01:01 pm Dec 27 2005
by kawboy2006
I just bought a 06 kdx 200 and am going to do this swap. However does anyone know if the outer kdx and kx bearing races can be removed from the frame? This would be great if they could be, So far I've read about all this knurling and shimming and dont like the idea,(got to be a bolt on solution perhaps not just asking.) if I could tap out the outer races from the frame none of this would need to be done. I have at my disposal a 03 kx 125 with blown motor and haven't even started yet, as there is no heat in garage. Please if anyone has info on these later year swaps I'd greatly appriciate it. thank and graet forum :cool: maybe I can get lucky does someone need my stock front end?
Posted: 01:36 pm Dec 27 2005
by Indawoods
Mr. Heater works great in the garage... 'bout $40 + Propane. :grin:
The bottom fits perfect so there is no problem there... same bearing and races... the top is a different story. I don't know if it is the design of the tube or what but I really didn't want to get into tearing out the races and seeing if a KX race would fit. Besides, I think the KDX tube is shorter... not for sure though....
Here's a pic of the top....
Posted: 03:31 pm Dec 27 2005
by KDX220PHIL
hmmm. I thought the KDX tube was longer....maybe not?
My Kdx front end is apart so I can check the race on thursday, it most likely can be removed since there is a part number on buykawasaki. I dont have a KX Race, but if looks as though even the bearing would not fit in the tube let alone the outer race.
I think the bolt on solution may lie with the KX500 TT's, although this may be for 94-98 year KX front ends.
I think GS might have some info on this?
Posted: 04:03 pm Dec 27 2005
by Indawoods
Well... now that we are on this... I might just see if my spares race can be replaced with a KX one. Sure seems like the ticket if the tube length is the same or close....
It would save all that machine work and make for a better setup in the longrun.
Posted: 04:06 pm Dec 27 2005
by KDX220PHIL
Hurry UP!!!! Before i start pumpin' out stems for nothin'. :grin:
Sure would be nice if it works, judging by the pic above it doesnt look like the bearing race will fit , although there may be options for making it fit.
Posted: 04:21 pm Dec 27 2005
by Indawoods
From what I see on buykawsaki.com is that the steering tube is flared on both ends of the KX frame to accommodate the larger races and bearings and only flared on the bottom of the KDX frame for the same. This it appears is where we are running into the problem.....
It don't look good.... :?
Posted: 04:32 pm Dec 27 2005
by Indawoods
Here's what I mean....
Posted: 07:43 pm Dec 27 2005
by kawboy2006
It appears my 06 has the same flare on bottom but not on top! let me know if that truly is a problem. and why the #$%% kawasaki would not upgrade this is beyond comprehension. one little upgrade in frame design and all our woes solved. $%#!
Posted: 07:45 pm Dec 27 2005
by kawboy2006
and where'd you get those diagrams i wanna closer look
Posted: 08:00 pm Dec 27 2005
by Indawoods
95 through current KDX frames are the same along with everything else.
http://www.buykawasaki.com has diagrams of all their bikes on there for easy parts identification and part numbers.
Posted: 08:02 pm Dec 27 2005
by kawboy2006
Thanks :cool:
Posted: 04:24 pm Dec 28 2005
by kawboy2006
Bet I can find a company to supply the rollar bearing needed with the smaller outside diameter of the kdx race with the larger inside diameter of the kx shaft there are many companies that sell any size tapered rollor bearings all I need now is a micrometer
if any one has the measurements already please let me know as this will speed up our search :supz:
Posted: 05:07 pm Dec 28 2005
by KDX220PHIL
I'll post the measurements tomor. but I think the bearings would end up being very small. If I remember correctly I think the Kx stem is about 1/8" larger in diameter than the KDX stem at the upper bearing. Also, If the KDX tube is longer than the KX tube ( I think it may be) it may result in the steering stem cap nut not reaching the stem thread (lower one). I'll check this out as well.
For clarity the nut I am refering to is the 25mm hook nut not the 22mm steering stem nut.
Posted: 06:14 pm Dec 28 2005
by canyncarvr
I can't point you to where...but I'm pretty sure this has all been hashed out before.
For starters. Sure, the outside race is easily removed.
Do NOT mix-n-match outers and inners...even if you think they look the same. They call it a matched 'set' for a reason.
Not all setups take the same assembly methods..but at the worst, it's still no big deal. As long as you get KX stuff that you KNOW goes together (all the same year is helpful), the stem swap isn't a big deal.
You should likely replace the bearings anyway. Well...an '06 should be OK...but not for very long!!!! If you have not already greased your bike..the bottom stem bearing is already on its way to being junk.
Re: shimming
Get a bushing made for the top KX clamp to fit the KDX stem. No shimming required. My machine shop bill for installing the stem and bushing the clamp was about $70.
Posted: 08:29 pm Dec 28 2005
by Domenic_200
I pressed a 03 kdx stem into the 02 kx lower triple..it took about six tons to do it..Plenty tight! I believe the later model kdx stems don't require knurling or shims. I used the kx bearing adjuster nut as a spacer below the upper triple also. I to was very concerned about having to shim or knurl the lower clamp, but it was very easy and the forks work great.
Domenic
Posted: 10:17 pm Dec 28 2005
by kawboy2006
Found a local one going to take measurements and see if they have them or can get em post later with results
Posted: 12:30 am Dec 30 2005
by Lutz
No need for a micrometer: All critical dimensions of a bearing are coded into their part numbers. These dimensions include the inner and outer races (i.e. a complete bearing). The bearings used in our bikes use the JIS (Japanese Industrial Standards) coding system.
The KDX top bearing is a 32005JR RS. This number codes out to be 47mm outside diameter, for a 25mm shaft, and 15mm wide. The JR RS basically refers to a one side sealed roller bearing.
The KDX bottom bearing, same as KX top and bottom bearings, is 32006JR RS. This bearing is 55mm outside, for a 30mm shaft, and 17.25mm wide.
This amounts to 0.315 inches difference outside, 0.197 inches difference in shaft size, and 0.089 inches difference in bearing width. That's over half an inch of material that would have to be taken out of rollers and races...that's just too much material to make it work.
Honestly, you won't be able to get a roller bearing that will allow you use the stock KX stem in the stock KDX head tube. But if you want to try anyway, good luck. :wink:
You'll have much better luck pressing stems, building bushings, etc. etc.
Posted: 12:34 am Dec 30 2005
by Indawoods
That's great info!
Thanks... I need to brush up on my engineering standards. (as if I knew any.. :? )
Posted: 10:07 am Dec 30 2005
by KDX220PHIL
Good info Lutz. I didn't make it home yestersay so I could not measure the bearings and thanks to your info looks like we do not need to.
One question is bothering me... why do some KDx's need knurling and others don't? which KDX's need a larger stem and what size?
Posted: 01:44 pm Dec 30 2005
by canyncarvr
The inside/outside measurement do not take the taper ยบ into account. If you're replacing the set, you don't care.
But..this thread started with an 'outer race' question.
The fact that IT is indeed easily removable..and that tapered roller bearings should be replaced AS a 'set' is clear...right?
kawboy?
lutz wrote:Honestly, you won't be able to get a roller bearing that will allow you use the stock KX stem in the stock KDX head tube. But if you want to try anyway, good luck.
Yup.
re: 'why...'
Because some stems are smaller and/or some clamp holes are bigger.
:shock:
Why ask why? Mixing different models and years of different stuff, wouldn't you expect some things to be not the same? I don't matter what you get, it WILL (or CAN) work.
The direct answer, of course, is:
canyncarvr wrote:I don't know.
You can quote me on that.
