KLX 650
KLX 650
Anyone now if is possible the conversion of the KLX 650 fork on a KDX 200 1998
- 6 Riders
KLX 650
sarrant wrote:KLX650 forks are inverted. I think they're a variation on KLX300 forks, and likely bolt straight on.
KLR650 forks are conventional.
Yes, but any 650 fork is gonna have some beefy springs in it.....650s are HEAVY bikes r/x doesn't matter, there is a lot of weight built into those machines and I'm sure the X is sprung properly for it. So plan on at the least putting a set of springs in (not that any other conversion would be different) and a re-valve.luisrspereira wrote:Anyone now if is possible the conversion of the KLX 650 fork on a KDX 200 1998
KLX 650
and the kdx??sarrant wrote:According to the parts diagram, they are .43 kg springs stock.
KLX 650
It is good for my 185 lbs?????luisrspereira wrote:and the kdx??sarrant wrote:According to the parts diagram, they are .43 kg springs stock.
Re: KLX 650
Are you 185 in gear or just 185 by yourself?
Pretty smart to get the more heavily sprung forks.
KLX650 should be as KLX300 or older KLX250.
Re: KLX 650
my wheight is 84 kg = 185lbsJason wrote:Are you 185 in gear or just 185 by yourself?
Re: KLX 650
so 200 pounds in full gear??
.43 will be very good.
KLX 650
Anyone now if the KDX wheel is compatibleJason wrote:so 200 pounds in full gear??
