Hi guys and gals,
I have a 1999 KDX200 just wondering if a set of 1997 KX125 forks and triples would bolt on or do they require some work?
Thank you in advance
97 KX forks on 99 KDX?
- Country: Australia
- 6 Riders
Re: 97 KX forks on 99 KDX?
They require some work.
Thanks, I'm thinking for the sort of riding I want to do I'll just get the OEM sprung for my weight and have them serviced (yes the rear as well)
- 6 Riders
For most trail work that is the best thing to do.....If you hit MX tracks, a fork conversion would be ideal, but only if you jump (real jumps).
I had the forks (USDs) on my 93 done up at a suspension shop...they are great for what I use the bike for....even in the high speed dessert, but I paid for that.
I'm doing a fork conversion on my 95 right now, using RM250 (showa) forks. It is EXPESIVE to have it all done (including having the forks valved and lowered) but I WILL put those forks to very good use!
- doctord23
They will bolt on if you replace the stem from the kdx into the triples of the KX.MaverickAus wrote:Hi guys and gals,
You will also need a spacer for the top. RB makes one.
You need the kx wheel and front axle as well.
The rear of the KDX is pretty good as is for mid-weight riders.
My Team Green:
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1988 White KDX 200C3
1984 KX500 (original owner)
1996 Honda Magna V4
2017 Honda Africa Twin DCT
2002 KX-KDX 220
2000 KDX 220
2003 KLX 300 DS
1996 Honda Magna V4
