Which caliper?
Which caliper?
After my fork swap, I re-used my kdx caliper. Would the 2002 kx 250 caliper be better, or were they basically the same? The KX caliper needs rebuilt, but I don't mind spending the money if it would be better. Thanks!
- KDXohio
Re: Which caliper?
The KX caliper I used with mine is a dual piston which was definitely an improvement over my stock single piston but my bike is an E series so maybe the H has a dual piston already?
