Page 2 of 2
My fork conversion
Posted: 01:31 am Jan 21 2014
by robkdx
Ive now got it apart and it seems to have 11 shims in the base valve. It looks like the shims have not been out before.
So remove 2 of the big shims in the base valve?
About to go out and pull down the mid valve and try to work out what they mean about the spring under the rebound is.
Re: My fork conversion
Posted: 02:11 am Jan 21 2014
by robkdx
So mid valve apart now, wow thats a shim stack in there.
So I replace the o ring with a little spring to allow that side on the stack to have .4mm movement? And drop 2 of the bigger shims out of that side?
I presume I leave the rebound stack alone.
Posted: 04:00 am Jan 21 2014
by robkdx
My fork conversion
Posted: 04:31 am Jan 21 2014
by robkdx
Posted: 09:18 pm Jan 21 2014
Yep, that is kawamaha's page. He has very good advice.
I would think a couple of the largest ones from the base valve and maybe one from the midvalve, leaving rebound alone.
Posted: 01:07 am Jan 22 2014
by robkdx
Jason wrote:Yep, that is kawamaha's page. He has very good advice.
Thats what I had been thinking, found the perfect springs for the mid valve. That lot will soften her up.
What oil weight? Was thinking 7.5.
Posted: 08:58 pm Jan 22 2014
5, just 5
Posted: 02:24 am Jan 23 2014
by robkdx
Thanks Jason.
Ive got one leg together and the other will be done on the weekend. Then I will re-lace the wheel as the KX wheel is dented and my KDX rim is perfect. Next week will be changing over the steerers.
Posted: 10:07 am Jan 23 2014
Check the rim's spoke nipple hole diameter. I seem to remember people saying something about them being different.
Posted: 03:35 pm Jan 23 2014
by 6 Riders
Jason wrote:Check the rim's spoke nipple hole diameter. I seem to remember people saying something about them being different.
Pretty sure the rims are the same. I have a wheel builder that wants my gold KX rim, he's gonna swap a KDX rim onto it, said it's just "undo the lacing and relace to new rim"
Posted: 02:36 am Jan 24 2014
by robkdx
Yes I measure everything before stripping them down. Im a bicycle mechanic by trade and a racing wheel specialist. These wheels look easy to me.
Posted: 11:36 am Jan 24 2014
by turtle
They are different in my experience. I laced a KDX rim onto a KX hub during my conversion. I had to drill out the rim to accept the spokes. No big deal, but it had to be done.
My fork conversion
Posted: 11:33 pm Jan 24 2014
by robkdx
Ive got something very wrong. One on leg when I compress it air and oil try to push past the outside of the main oil seal. Not by the fork leg but around the outside of the seal.
Any ideas?
Posted: 01:49 am Jan 25 2014
by robkdx
Worked it out, somebody has hit the fork upper with something. Its now slightly oval. Not quite sure how to fix it at this stage. Its not out by much but enough.
My fork conversion
Posted: 02:51 pm Jan 25 2014
by robkdx
Ok, changed the new All Balls brand seals back to the stock seals and bingo its fine.
I will order some new OEM ones.
