Page 6 of 7
Posted: 11:23 am Jun 15 2010
by KC-10ENG
Thanks! I am going the complete dual sport route with this bike. I have a 2006 KTM200 for my trail bike.
Posted: 02:31 pm Sep 13 2010
by heckler
Posted: 08:42 pm Oct 26 2010
by jjon456
Sorry to be redundant and ask questions already answered but im going crosseyed reading all this.
1) what are the advantages if any of kx 125/250 forks over kx500. as i understand it the kx 500 is just a swap with no machine work ect.
2)would klx 300 forks be a strait swap
I ask because ive found a set of kx 500 forks triple and wheel from brenda at bike bone yard for $175 for the forks/tripple and $75 for the wheel and axle. I dont really have a "shop" right now (more of a leaky shead) and there really arent any good machine shops here so im looking for a bolt on project I can do in a weekend.
Im a nub and have only had my 1996 kdx 200 for a year and its one of the funnest trail bikes ive ever riden so I wanna do all the upgrades this winter while its snowing here in colorado.
Thanks and if anyone is in colorado lets ride!
Posted: 09:01 pm Oct 26 2010
by frankenschwinn
They are all kyb forks using the same technology in any given year. Spring weights will differ to accommodate the heavier 250/500 motor/chassis/riders. 125 motor chassis and riders tend to be lighter so spring rates will be lighter on those. All of them need to be sprung for your weight/riding style and valved accordingly. I don't know about the fitment of the klx300 stem on the KDX frame.
Posted: 09:02 pm Oct 26 2010
by Indawoods
A KX500 frontend is a direct bolt on operation and sounds like your best option.
Posted: 09:18 pm Oct 26 2010
by jjon456
sweet thanks
thats what I was thinking inda
just make sure I had it right before I made the purchase.
Posted: 10:08 pm Nov 28 2010
by G22inSC
With the KX500 direct bolt on option, can you use the KDX wheel/axle or do you still need a complete front end (KX500 fork/tree/wheel/axle)? Trying to research and decide the best route to go.
Posted: 10:15 pm Nov 28 2010
by SS109
You cannot use the KDX wheel and axle. You have to use all KX parts.
Posted: 10:26 pm Nov 28 2010
by Mr. Wibbens
SS109 wrote:You cannot use the KDX wheel and axle. You have to use all KX parts.
Why not?
Posted: 10:29 pm Nov 28 2010
by G22inSC
Thanks. That is what I was thinking; however, I was not positive. Just can't decide...put money towards conversion or new springs and gold valves. I mainly ride mountainous trails but I do occasionally hit tracks with friends just for fun. Just can't get off the fence one way or the other.
Posted: 10:45 pm Nov 28 2010
by SS109
Posted: 11:03 pm Nov 28 2010
by Mr. Wibbens
So it can be done
Posted: 11:28 am Nov 29 2010
by SS109
2006 KX450F KYB fork (48 mm) to my 2005 KDX 220
Posted: 03:46 pm Jun 09 2011
by heckler
Thanks to all the people who's helped make this project a reality!
Here's a better drawing of the perfect spacer to fit my 2006 KX450F top crown to my 2005 KDX stem. I'm sure RB does a great job of this, but I've got too much mechanical engineering and a machine shop at my disposal to not do this myself.
No knurling required, although I am making a 30.1 mm ID X 38 mm OD x 1.9 mm thick washer to fit between the lower bearing and the bottom crown. The KDX stem has 1.8 mm of material that has not been ground that sticks out from the lower KX crown and will slightly lengthen the KDX stem fit into the headtube. Not sure if I need it, but my machinist works for cheap.
I'm currently working on changing the oil to 5WT, and next up with be figuring out how to revalve them for woods for a 180 lb rider. If anyone has any shimstack combos they'd like to share for this, I'm all ears.
Re: 2006 KX450F KYB fork (48 mm) to my 2005 KDX 220
Posted: 05:48 pm Jun 15 2011
by heckler
This turned out to be a bad idea. No washer/spacer needed, and now I have to get my brand new lower bearing off to remove the washer.
I don't have enough thread engagement at the upper end of the stem.
Posted: 06:15 pm Jun 15 2011
by Mr. Wibbens
bummer
go find someone with a press
KX fork conversion recap?
Posted: 09:00 pm Jun 21 2013
by KDXohio
Are 89-92 kx 125/250 forks not worth the conversion?
Are they just not much of an improvement over stock?
Or if one could do a rather cheap conversion with them would it be worth while? (By cheap i don't mean cut corners or install junk)
I have a 90 kdx200 I weigh 145lbs I have found an 89-92 250 front end complete for 90$ Piecing together a newer front end is looking like a 300-500$ investment machine work included
So with that being said I have a 1999 kx125 for the track but I'd like my kdx to be track capable as well but mostly going to be woods riding.
Any help is much appreciated be honest I'm new to suspension work so I need all the advise I can get. I'm more than capable of rebuilding, revalving, adjusting....etc but just because someone can do something doesn't mean they know what they are doing.
Re: KX fork conversion recap?
Posted: 11:27 am Jun 22 2013
by Goofaroo
What's wrong with the stock forks?
Posted: 03:03 pm Jun 22 2013
by KDXohio
Goofaroo wrote:What's wrong with the stock forks?
They're too soft, I'd like to have the rebound adjust-ability that the USD has and I like that the USD forks stop at the axle so on the trail I don't have to worry about hitting the bottom of the forks on anything. I basically just want the bike to be more track friendly but I dont want to sacrifice woods riding as I have a kx125. I know ill have to mess with the valving of whatever I get to make MX forks woods friendly.
Posted: 09:00 pm Jun 22 2013
by Goofaroo
What weight oil are you running in your forks? Fluid level? Stock springs?
There are some basic things you could try before you just give up on the stock forks. They are actually a very nice set-up for woods riding.
