Sold The Wrong Forks
RailwayRog
Post by RailwayRog »
I bought what I was told a 2002 KX 250 front end, well when i went to replace the seals and bushing guess what, the new bushing and seal are just a tad to big.
The kit I bought was for model years 2002 thru 2004 (Pivot Works PWKKK-K05-021).
So not only I'm I pissed I don't know how to identify these forks.
Anybody know a way i can identify the forks?
Anybody want to buy a fork kit listed above?
Re: Sold The Wrong Forks
If you have a caliper and caan measure the tube diameter you could probably get close, but it'll take a bit of work on your part researching it. From what I could find for KX250 USD forks inner tube diameter:
2002 - 2007: 48mm
1996 - 2001: 46mm
1991 - 1995: 43mm
1990: 41mm
Hope that helps
scheckaet
Post by scheckaet »
i had a similar issue with my 2002 kx 125 fork, bushing (rmatv aftermarket) would NOT go in ... got impatient so very carefully I filed the excess till they got in...
RailwayRog
Will any 46mm KYB seals and bushings fit?
