Need some Info...
SAPPER
Need some Info...
Post by SAPPER »
Hi guys i have a 2005 kx250 and i was thinking of doing a 2008 or newer kx450f front assembly swap due to hearing the suspension is 10x what it was in 2005. What i want to ask is how difficult is this task? What goes into the procedure of swapping the front assembly?
I also own a 2003 kx125 i was thinking of doing the 2008 or newer kx250f front assembly on for once again the suspension purposes. has anyone tried this?
real men measure with inches not centimeters
kx125 mine
kx250 dads
kx65 sisters
lt-z250 moms
kdxtreme
Need some Info...
Post by kdxtreme »
I have a 2009 kxf250 front end on my 2005 kx220 its a bolt on but the fork is 18mm longer so you have to slide the forks up in the triples to compensate for the extra length.
Did I say riding?
