2003 kdx
2003 kdx
Hey guys! I know it's probably been asked. But!!!! What year KX front end would be best to get for my 2003 KDX. I also understand that I ned the whole frontend of the KX apart from stem! I also understand that I can use the KDX caliper and brake line. Correct? Sorry to be a pain!
- rbates9
There is WAY too many threads on this. You probably should do some reading.
Look for the newest forks you can find. The 500's should slip right on, the 125's and 250's are more plentiful.
125's tend to be the same forks as 250's with exception to the springs being heavier on the 250's. If your on the heavy side try to find the 250's, if your a light weight look for the 125's. If you are planing on respringing any way get the best deal you can find.
