Changing front forks to KX250f front forks
Posted: 03:36 pm May 02 2016
by Roman220
Hey I have a 2003 KDX220R and I want to swap the front forks out to a 2004 KX250F front ones. I know I will need the lower tree triple clamp but im not sure ill need anything else.
Re: Changing front forks to KX250f front forks
Posted: 03:59 pm May 02 2016
by doctord23
Upper and lower clamps for the KXF plus swap out the stem plus a spacer / shim from Ron Black.
That will do it. You can make your own spacer and shim, but buying one is easier and cleaner.
Posted: 01:14 am May 03 2016
by 6 Riders
You'll need the kx front wheel as well. Brakes should swap over, everything else needs to ne changed. You also need to modify the steering stops.
Posted: 10:39 pm Dec 11 2016
by Pipeliner
Where can you buy the spacer for this conversion?
Posted: 01:18 am Dec 12 2016
Make your own or check with Ron Black. RB Designs
